I have a 4 GB USB stick and I am going to write the Xubuntu iso file into it. Will 4 GB be enough?
Asked
Active
Viewed 1,117 times
XFCE 20.04 Iso has 1.74 GB, so your stick is large enough.
Since the answer to this question is so obvious, I'd like to mention, that I am referring to an USB-Stick that is used to install it on a hardware.
If you want to install Xubuntu on an USB stick (not recommended but possible), then you should have at least 8GB.
kanehekili
- 7,426
Yes, this will work. I wrote this image on a 2GByte SD-Card.
You can write the Image on a USB-Stick to create a installation-USB-stick, so that you can install XUbuntu on your PC or Laptop with this stick.
You should use the Belena-Etcher for this, it is very easy you only have to select the right Flash-Drive. https://www.balena.io/etcher/
MikroPower
- 394
