Sorry if this has been posted before, I searched previous questions but didn't find one that fit my specific issue and laptop model.
As the title says I just upgraded from Ubuntu 16.04 LTS to 20.04 LTS and now the wifi icon at the top doesn't show up and when I search Wi-Fi settings I get "No Wi-Fi adapter found"
I have access to a USB to ethernet adapter if I need to download any drivers or install updates and have already disabled secure boot in the BIOS options.
I ran lspci and my network controller is Intel Corporation Wireless 8260 (rev 3a)
uname says my kernel version is 5.4.0-1035-gke
Let me know if I should gather any further info or if I should just replace my wireless card, and if so which one is the best replacement.
Thanks!
Edit: my ethernet adapter isn't working either so I don't currently have internet access on the laptop. In order to get the ethernet working I had to boot into a different kernel available to me on restart (5.4.0-65-generic)
Output from sudo lshw -c network with kernel 5.4.0-1035-gke:
*-network UNCLAIMED
description: Network controller
product: Wireless 8260
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:3a:00.0
version: 3a
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: memory:dc200000-dc201fff
Output from sudo lshw -c network with kernel 5.4.0-65-generic:
  *-network
       description: Wireless interface
       physical id: 0
       logical name: wlp58s0
       version: 3a
       serial: e4:a7:a0:8f:85:68
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=5.4.0-65-generic firmware=36.77d01142.0 ip=192.168.2.20 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:136 memory:dc200000-dc201fff
  *-network
       description: Ethernet interface
       physical id: 2
       bus info: usb@2:1
       logical name: enx000ec6bd7ad0
       serial: 00:0e:c6:bd:7a:d0
       capacity: 1Gbit/s
       capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=ax88179_178a duplex=full ip=192.168.2.106 link=yes multicast=yes port=MII speed=1Gbit/s
No additional drivers are available in the software and updates center
Edit2: My wireless card also seems to be working now that I'm using the older kernel, should I continue booting into this kernel then and that solves my issue? Are there any issues with doing this and will future updates create more problems?
Whenever you have a dual boot system with Windows the fast boot mechanism of Windows may cause problems. Thus, turn it off in Windows as explained in this post here and the issue may go away. At least my Thinkpad L480 running Debian Bullseye accepted the solution.
