I use (k)ubuntu to work, and now that I have to use video call applications daily, I've noticed the subpar quality of my integrated mic. I know my bluetooth headset works as a headset because I've used it on my phone as a bluetooth headset, and it even shows up in the volume mixer as a headset. When I connect the headset to my pc, I can use a2dp(stereo playback), but cannot use my microphone. When I try to switch to hsp/hfp in pulseaudiovolumecontrol, I can hear my own voice echoing in my headset, but can no longer hear anything from my pc. However, I can see in my volume manager that the microphone is now available(although it doesn't work). here are some details on my hardware:
my wifi/bt card according to lspci:
3b:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
PACMD output:
index: 2
driver: <module-bluez5-device.c>
owner module: 28
properties:
device.description = "JLab BT"
device.string = "FC:58:FA:C4:9D:17"
device.api = "bluez"
device.class = "sound"
device.bus = "bluetooth"
device.form_factor = "headset"
bluez.path = "/org/bluez/hci0/dev_FC_58_FA_C4_9D_17"
bluez.class = "0x260404"
bluez.alias = "JLab BT"
device.icon_name = "audio-headset-bluetooth"
device.intended_roles = "phone"
profiles:
headset_head_unit: Headset Head Unit (HSP/HFP) (priority 30, available: unknown)
a2dp_sink: High Fidelity Playback (A2DP Sink) (priority 40, available: yes)
off: Off (priority 0, available: yes)
active profile: <a2dp_sink>
sinks:
bluez_sink.FC_58_FA_C4_9D_17.a2dp_sink/#8: JLab BT
sources:
bluez_sink.FC_58_FA_C4_9D_17.a2dp_sink.monitor/#12: Monitor of JLab BT
ports:
headset-output: Headset (priority 0, latency offset 0 usec, available: yes)
properties:
headset-input: Headset (priority 0, latency offset 0 usec, available: unknown)
properties:
Also now looking at my journal for bluetooth-related errors I see some lines that raise questions:
Unable to get io data for Headset Voice gateway: getpeername: Transport endpoint is not connected (107)
Failed to release transport
/org/bluez/hci0/dev_FC_58_FA_C4_9D_17/sep1/fd7: Method "Release" with signature "" on interface "org.bluez.MediaTransport1" doesn't exist
Bluetooth: hci0: Failed to send Intel_Write_DDC (-22)
Update: I tried to update to groovy gorilla, as I thought that it may remedy my issue as stated in https://bugs.launchpad.net/ubuntu/+source/pulseaudio/+bug/1871794 but it didn't work out, so I've updated the title to 20.10
