I've just upgraded my ubuntu from 18.04 to 20.04 and immediately realized that I could not open settings. I read that the problem has to do with gnome-control-center, but when I use
sudo apt install gnome-control-center
I get
Reading package lists... Done
Building dependency tree
gnome-control-center : Depends: libcheese-gtk25 (>= 3.18.0) but it is not going to be installed
Depends: libcheese8 (>= 3.28.0) but it is not going to be installed
Depends: libgoa-backend-1.0-1 (>= 3.10.0) but it is not going to be installed
Recommends: gnome-online-accounts (>= 3.25.3) but it is not going to be installed
Recommends: gnome-user-docs but it is not going to be installed
Then, I found this discussion here and tried to follow each presented solution to fix this unmet dependencies problem. Unfortunately, nothing worked.
My next attempt was to follow this instructions here. So I started adding each package dependecy in my sudo apt install command, and then new dependecies appeared and a repeted the process. My final command was
sudo apt-get install gnome-online-accounts gnome-control-center gnome-user-docs libcheese-gtk25 libcheese8 libgoa-backend-1.0-1 libwebkit2gtk-4.0-37 ubuntu-docs yelp libclutter-1.0-0 libclutter-gtk-1.0-0 libcogl20 gstreamer1.0-clutter-3.0 libgl1 libgstreamer-gl1.0-0 libgl1-mesa-dri libglvnd0 libglx0 libglapi-mesa libglx-mesa0
for which the output was
libglapi-mesa is already the newest version (20.2.0~kisak1~b).
libglvnd0 is already the newest version (1.3.2-1~kisak~b).
libgl1 : Depends: libglvnd0 (= 1.3.1-1ubuntu0.20.04.1) but 1.3.2-1~kisak~b is to be installed
libgl1-mesa-dri : Depends: libglapi-mesa (= 20.0.8-0ubuntu1~20.04.1) but 20.2.0~kisak1~b is to be installed
libglx-mesa0 : Depends: libglapi-mesa (= 20.0.8-0ubuntu1~20.04.1) but 20.2.0~kisak1~b is to be installed
libglx0 : Depends: libglvnd0 (= 1.3.1-1ubuntu0.20.04.1) but 1.3.2-1~kisak~b is to be installed
After that, I get the same output if I add libglvnd0 and libglapi-mesa at the end of my sudo apt install command. I don't know what to do next and I am kind of desperate and very afraid of rebooting my computer.
