So, when I installed Ubuntu 20.04 LTS onto my PC firstly I removed Nautilus (Because I prefer to use Nemo) and after this action my system has a lot of broken files that can't be removed (I tried and it's said that I have more and more broken files) and the command sudo apt install -f doesn't work at all. How can I fix it? I cannot install even Steam now also my system is up to date!
PS. aptitude doesn't work as well as apt.
sudo apt install steam
sudo password for lambleeg:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: steam:i386 : Depends: libgl1-mesa-dri:i386 (>= 17.3) but it is not going to be installed or libtxc-dxtn0:i386 but it is not installable Depends: libgl1-mesa-dri:i386 but it is not going to be installed Depends: libgl1-mesa-glx:i386 but it is not going to be installed Depends: libudev1:i386 but but it is not going to be installed E: Unable to correct problems, you have held broken packages.
karel
  • 122,292
  • 133
  • 301
  • 332
