Before the update every time I logged in I used to disable my laptop's touchscreen. But since the new update I am not able to disable the touchscreen.
Command xinput disable 9 doesn't works anymore. Someone please help. I have other methods too but none of them worked.
And also I get logged out my account and all applications gets closed automatically and I have to re login. It usually happens when I use the touchscreen. This is only happening after this new update.
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.4 LTS
Release:    18.04
Codename:   bionic
Virtual core pointer                        id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ xwayland-touch:15                         id=9    [slave  pointer  (2)]
⎜   ↳ xwayland-pointer:15                       id=6    [slave  pointer  (2)]
⎜   ↳ xwayland-relative-pointer:15              id=7    [slave  pointer  (2)]
⎣ Virtual core keyboard                     id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ xwayland-keyboard:15                      id=8    [slave  keyboard (3)]
Edit /usr/share/X11/xorg.conf.d/40-libinput.conf file and in
Section "InputClass"
        Identifier "libinput touchscreen catchall"
        MatchIsTouchscreen "on"
        MatchDevicePath "/dev/input/event*"
        Driver "libinput"
EndSection
replace libinput in driver section to evdev, so it will be:
        Driver "evdev"
EndSection
Then restart and try to login.
People here did the same for evdev configuration making it invalid by replacing evdev to libinput. In this way they disabled touchscreen.
If you have /usr/share/X11/xorg.conf.d/10-evdev.conf file, then change evdev to libinput in Driver section for this case.
Gryu
  • 8,002
  • 37
  • 53
