KDE baloo has recently caused rsyslog to start logging many errors.
Part of 'Syslog'
Mar 3 15:01:53 harry-S340 baloo_file.desktop[2982]: org.kde.baloo.engine: PositionDB::put MDB_BAD_TXN: Transaction must abort, has a child, or is invalid
Mar 3 15:01:53 harry-S340 baloo_file.desktop[2982]: org.kde.baloo.engine: PostingDB::put MDB_BAD_TXN: Transaction must abort, has a child, or is invalid
It caused my /var/log/syslog to grow exponentially, it filled the disk once already, I've since disabled rsyslog to stop this from destroying my SSD and making Ubuntu unusable but I don't know what Baloo is or how to stop and uninstall it. When i fist noticed this /var/log/syslog had grown to 66GB causing my disk to be FULL. I was able to delete it and log back in and disable rsyslog through recovery mode. Running rsyslog for one second caused it to go up to 75MB.
'Neofetch --off' result
OS: Ubuntu 19.10 x86_64 Host: 81NC Lenovo IdeaPad S340-15API Kernel: 5.3.0-40-generic Uptime: 11 mins Packages: 3040 (dpkg), 38 (snap) Shell: bash 5.0.3 Resolution: 1920x1080 DE: GNOME WM: Mutter WM Theme: Adwaita Theme: Yaru-dark [GTK2/3] Icons: Yaru [GTK2/3] Terminal: gnome-terminal CPU: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx (8) @ 2.100GHz GPU: AMD ATI 04:00.0 Picasso Memory: 2756MiB / 5945MiB
I don't want to uninstall the whole of KDE straight away but if that is the only way to get rid of this broken program then I happily will.
Other commands
harry@harry-S340:~$ whereis baloo
baloo:
harry@harry-S340:~$ sudo apt-get autoremove baloo
[sudo] password for harry:
Reading package lists... Done
Building dependency tree
Package 'baloo' is not installed, so not removed
0 to upgrade, 0 to newly install, 0 to remove and 4 not to upgrade.
harry@harry-S340:~$ whereis baloo_file
baloo_file: /usr/bin/baloo_file
harry@harry-S340:~$ sudo apt-get autoremove baloo_file
E: Unable to locate package baloo_file
harry@harry-S340:~$ sudo systemctl status baloo_file
Unit baloo_file.service could not be found.
Pressing tab to see all the commands that have baloo in them:
harry@harry-S340:~$ baloo
balooctl baloo_filemetadata_temp_extractor
baloo_file baloosearch
baloo_file_extractor balooshow
these all don't have any manuals
harry@harry-S340:~$ man baloo
No manual entry for baloo
harry@harry-S340:~$ man baloo_file
No manual entry for baloo_file
harry@harry-S340:~$ man balooctl
No manual entry for balooctl
harry@harry-S340:~$ man baloosearch
No manual entry for baloosearch
harry@harry-S340:~$ man balooshow
No manual entry for balooshow
harry@harry-S340:~$ man baloo_filemetadata_temp_extractor
No manual entry for baloo_filemetadata_temp_extractor
harry@harry-S340:~$ man baloo_file_extractor
No manual entry for baloo_file_extractor
Desktop file mentioned in syslog
[Desktop Entry]
Type=Application
Exec=baloo_file
X-KDE-StartupNotify=false
X-KDE-autostart-condition=baloofilerc:Basic Settings:Indexing-Enabled:true
X-KDE-autostart-phase=0
X-GNOME-Autostart-enabled=true
OnlyShowIn=KDE;GNOME;Unity;XFCE
NoDisplay=true
Requests
Balooctl status
harry@harry-S340:~$ balooctl status
Baloo File Indexer is running
Indexer state: Indexing file content
Total files indexed: 109,311
Files waiting for content indexing: 3
Files failed to index: 4
Current size of index is 507.65 MiB
harry@harry-S340:~$ sudo balooctl disable
Disabling and stopping the File Indexer
this stopped rsyslog filling up /var/log/syslog.
Thanks, Harry
