I want to hide the panels via script.
in maverick I used gconftool-2 --set "/apps/panel/toplevels/top_panel_screen0/auto_hide" --type bool "true"
now I tried
      gsettings set org.gnome.gnome-panel.layout ...
but there is a problem:
     gsettings list-keys org.gnome.gnome-panel.layout
tells me:
     object-id-list
     toplevel-id-list
but in dconf editor there are 2 subfolder layers called toplevels and then top-panel /bottom-panel I have no idea how to get there.
it should be
toplevels.top-panel auto_hide true
I tried all different things to get there...no way. does that mean you cannot change these values from commandline any more?
fossfreedom
  • 174,526
As an alternative to gsettings you can use dconf from the command line as well.
For example
dconf write /org/gnome/gnome-panel/layout/toplevels/bottom-panel/auto-hide true
This will write the value TRUE to the auto-hide key.
If you need to see the keys in a path then use the list parameter
For example:
dconf list /org/gnome/gnome-panel/layout/toplevels/top-panel/
Remember to start with a / and end with a / for paths.
fossfreedom
  • 174,526
