I used to work with a dual screen setup (Lenovo P50 + external monitor). For an unknown reason, the external monitor stays black and seems not to be detected. When I use gdm3, only the builtin monitor is used, and when I switch to lightdm, only the external one is used, never both. I tried with several nvidia drivers (from 390 to 430), I also tried with the open-source one. I tried to purge then reinstall Nvidia drivers, manually install them, but the result is always the same, only one display at a time. I know that the GPU works as the two monitors are used when I dual boot on Windows.
Any idea on how to fix that ?
source gdm3 disables external monitors when options nvidia-drm modeset=1 is set. You can choose:
  • modeset=1: No screen tearing, can't use external monitors
  • modeset=0: Screen tearing, but can use External monitors
The fact it wouldn't work in lightdm still is a bit odd. I recall reading somewhere there's an issue with external monitors where it will try to output via VGA even if the monitor is connected by other means.
