Since I've installed kubuntu 19.04 my computer is not able to boot all the time. I thinked it was a grub option because some things are changed from the previous version 18.04 (which works fine for me), but in fact I can make nomodeset [nouveau/nvidia].modeset=0 or many other strange things, my computer just get stuck on black screen once in five. By the way, it makes the same trouble with the installation media
And if I press the esc key on boot, it just stay black and doesn't change anything ...
config of my pc : i7 8650U + gtx 1050m
(Please correct me if my english is bad and you want to help me ;-) )
In GRUB, press e to edit the linux startup command line and add dis_ucode_ldr at the end of the line that starts with linux /boot/... so that the line will look something like:
linux    /boot/vmlinuz-4.18.0-20-generic root=UUID=63771674-8044-4df4-\
         b700-17bcc857432d ro quiet splash $vt_handoff dis_ucode_ldr
and you'll be able to boot.
(Remove quiet splash if you want to check the system boot logs).
Add the same parameter dis_ucode_ldr to GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash dis_ucode_ldr"
then run
update-grub
and then you should always be able to boot, as-is, so without editing the command in GRUB.
See - and if possible, subscribe to - this Ubuntu bug tracker for more information:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1829620
Bludzee
  • 156
