I have a smaller, LUKS-encrypted ssd. I want to help get longevity if I can. I'm not sure how TRIM comes into play for an encrypted drive. I've looked at this Q&A on TRIM, and my main drive is good.
The drive does not mount on bootup. I normally click the icon in the Other Places tab, enter the password, and mount the drive. I do not want to auto mount the drive on boot. Thank you.
update -- trim is enabled on the primary ssd, with no entry for the other (unmounted) ssd. Can I mount the drive without decrypting, so as to run the trim service? I'm curious about the line with
errors=remount-ro o 1as well.~ systemctl status fstrim.timer ●[solid green] fstrim.timer - Discard unused blocks once a week Loaded: loaded (/lib/systemd/system/fstrim.timer; enabled; vendor preset: enabled) Active: active (waiting) since Sun 2019-04-14 06:03:18 CDT; 14h ago Trigger: Mon 2019-04-15 00:00:00 CDT; 3h 38min left Docs: man:fstrim Apr 14 06:03:18 home systemd[1]: Started Discard unused blocks once a week. ~ systemctl status fstrim ●[solid white] fstrim.service - Discard unused blocks on filesystems from /etc/fstab Loaded: loaded (/lib/systemd/system/fstrim.service; static; vendor preset: enabled) Active: inactive (dead) Docs: man:fstrim(8) ~ systemctl cat fstrim # /lib/systemd/system/fstrim.service [Unit] Description=Discard unused blocks on filesystems from /etc/fstab Documentation=man:fstrim(8) [Service] Type=oneshot ExecStart=/sbin/fstrim -Av ~ cat /etc/fstab # /etc/fstab: static file system information. # # Use 'blkid' to print the universally unique identifier for a # device; this may be used with UUID= as a more robust way to name devices # that works even if disks are added and removed. See fstab(5). # # <file system> <mount point> <type> <options> <dump> <pass> # / was on /dev/sda1 during installation UUID=#############-####-####-########### / ext4 errors=remount-ro 0 1 /swapfile none swap sw 0 0
