I have problem with scanning on LJ M1132 MFP printer/scaner. My search on many various forums did not get anywhere so I try to ask directly if someone can help me.
I recently reinstall system from Mate 16.04. to Ubuntu 18.04. In 16.04. the scanner had no problems. After installation of new system I had problems even with the printing. I installed newest hplip. Printing works for some time but scanning was not possible. All the time it show i/o problems.
For example "simple scan" shows warning "Unable to connect to scanner".
If I run
hp-scan
it comes with "error: SANE: Error during device I/O (code 9)"
I try several tips, like reinstalling hplip, so now I have instaled 3.18.6 version, but no change in scanning.
If I run
hp-check -t
from my point important part of output is
| HPLIP CONFIGURATION |
HPLIP-Version: HPLIP 3.18.6
HPLIP-Home: /usr/share/hplip
HPLIP-Installation: Auto installation is supported for ubuntu distro  18.04 version
Current contents of '/etc/hp/hplip.conf' file:
# hplip.conf.  Generated from hplip.conf.in by configure.
[hplip]
version=3.18.6
    | Scan Configuration |
     scanext              Scan-SANE-Extension                                          REQUIRED        -               3.18.6          OK         -
     hpaio                HPLIP-SANE-Backend                                           REQUIRED        -               3.18.6          OK         'hpaio found in /etc/sane.d/dll.conf'
    | DISCOVERED SCANNER DEVICES |
    device `hpaio:/usb/HP_LaserJet_Professional_M1132_MFP?serial=000000000QH6ADT0PR1a' is a Hewlett-Packard HP_LaserJet_Professional_M1132_MFP all-in-one
    | DISCOVERED USB DEVICES |
      Device URI                        Model
      hp:/usb/HP_LaserJet_Professional  HP LaserJet Professional M1132
      _M1132_MFP?serial=000000000QH6AD  MFP
      T0PR1a
    | PERMISSION |
    USB             HP_LaserJet_Professional_M1132_MFP Required        -        -        OK       Node:'/dev/bus/usb/005/005' Perm:'  root  lp rw- rw- rw- rw- r--'
    No errors or warnings.
As was suggested to install Plug-in, it is already installed together with the hplip. Even for printing my printer needs Plug-in. For versions of hplip 13.16.9 and 13.18.6 which were installed on my computer (together with similar version of plug-in) printing was working but scaner no. And my printer is not the latest model, according to the https://developers.hp.com my printer should be supported with hplip from version 3.10.4.
P.J.
  • 33
