I installed Ubuntu 11.10 on my HP laptop and among some problems, one of which I'm trying to solve is the touchpad problem. It's working, but how can I turn on/off it?
In SUSE Linux Enterprise Desktop (which was preinstalled) and Windows, the touchpad is enabled/disabled by touching the left upper corner, when small diode is situated. In Ubuntu, I touched that area many times, but nothing happened.
Do anybody know how to solve the problem?
Yi Jiang
  • 1,206
Dan
  • 219
Problem is still unsolved.
But if nobody has any thoughts about how to fix that - here is a possible solutions to help those, who can see this topic (guys from russian linux forums helped me).
You can type in your console:
syndaemon -t -i 2 -d
This means, that your touchpad will be disabled until 2 seconds after your typing will passed.
But there is a way to fix problems with turning off\on your touchpad and with enabling LED works properly... But this way is complicated. You must download this patches http://abhinandh.com/post/4336662463/getting-the-double-tap-on-the-led-to-disable-touchpad One patch is for kernel and one for xorg server. Also you have to change function parameters.
Dan
  • 219
I was just looking up this same issue for my HP g7. Have you tried the suggestion posted here:
https://askubuntu.com/a/85866/46766
It's not a completely satisfactory solution as it does not re-enable the upper-left corner "diode". But it sounds like it may reduce incidents where brushing the keypad while typing makes a mess of everything.
klenwell
  • 4,219
I've an HP G62 laptop, and I had the same problem. I resolved installing touchpad-indicator, which let you disable and enable the touchpad with a shortcut (for example, I use ctrl+alt+p to do that).
To install it you should follow the same instructions:
sudo add-apt-repository ppa:atareao/atareao
sudo apt-get update && sudo apt-get install touchpad-indicator
It's available both for 11.10 and for 12.04, now.
