I got an old machine with 16.04. The SSD is split in two partitions, one for root and one for home. The home partition is encrypted. Not sure of the details, I just used the wizard when 16.04 was installed.
Can I use a 18.04 boot-able USB to install Ubuntu in the root partition (wipe it) and use the encrypted home partition I already have? Say I use the same username and password for the new install, would that work?
givanse
  • 601
Based on @Organic Marble comment/answer, what I did was to flash a USB with Ubuntu 17.10 and used that to reinstall the OS.
In the installation wizard I selected:
  • Something else (when deciding what to do with the disk)
  • Selected my Root partition to be reformatted and mounted as an Ext4
  • Selected my existing encrypted home partition to be mounted as an Ext4, no reformat
  • When asked to set up a username and password I used the same pair I was already using
It worked perfectly, no surprises, no pain.
Once 17.10 is installed, you can do the upgrade to 18.04, if you still feel like it.
givanse
  • 601
