I had a similar issue trying to get my HP Stream 11 (model: 11-r015wm) netbook connected to WiFi.
lshw -C network told me it was a Broadcom BCM43142 wireless card. Come to find out it's a WiFi + Bluetooth combo card with (anecdotally - I tried about 6 different Linux distros) not a lot of support out of the box.
I settled on using Ubuntu Budgie and similar to your experience, when running from the live CD, I could get the wireless card to work if I manually downloaded and installed the driver and some dependencies:
bcmwl-kernel-source, linux-libc-dev, libc6-dev & dkms .deb packages. It was like magic when on the last command sudo dpkg -i bcmwl-kernel-source_6.30.223.271+bdcom-0ubuntu4_amd64.deb my WiFi turned on and starting working.
I naively thought all I needed to do now was to install the OS from the live CD and install those same .deb packages. With my new and working internet connection I installed the OS on my hard drive and made sure to tick off the box about installing updates and third party software/drivers.
However, after I finished the installation and restarting, this time around when I attempted to install dkms it said I was missing dpkg-dev, make & gcc. Wait what? Perhaps the live CD contains more software or is more robust than a standard installation?
Anyways, I started to manually install each dependency as they came up by going to https://pkgs.org/ and transferring over the .deb files with a USB. By my fourth transfer I was pretty salty.
This is what I did to finally end up solving the issue:
1) Found and downloaded my driver with all of its dependencies to a USB using this method:
https://stackoverflow.com/questions/22008193/how-to-list-download-the-recursive-dependencies-of-a-debian-package
1.5) Then I attempted to install all of the .deb packages and resolve dependencies by adding a local directory to /etc/apt/sources.list.
reference:
https://www.linuxwave.info/2009/04/adding-local-directory-to-apt.html
I then ran sudo apt-get update --allow-unauthenticated
reference:
Force update from unsigned repository Ubuntu 16.04
However, my package dependencies were still not resolving correctly. I was trying to run sudo dpkg -i *.deb on the folder where I saved everything but dpkg wasn't sure about which order to process all my .deb files in. So I tried something else instead..
2) I copied all of my .deb files into /var/cache/apt/archives and followed the answer here:
https://unix.stackexchange.com/questions/366488/how-to-use-dpkg-i-to-install-package-and-dependencies-where-dependencies-are-al#366886
by running sudo apt-get install -f it installed all of my dependencies and my WiFi finally turned on.
What a mess! And I'm quite surprised about the inconsistency between booting from a live CD vs installing and booting from my hard drive.
