I Have downloaded Ubuntu 18.04 LTS on to my computer (which is a Intel Chromebook) I have looked all over the web (including ask ubuntu) but have no answers that work. Can someone please help!!!
Thanks!!
Don't know if this will help but I also had this issue when trying to use ubuntu 16.04 with an acer chromebook
The solution was listed here in this answer - No Sound on Ubuntu 15.10 running on Acer CB3-111-670 Chromebook
I have only just installed xubuntu 18.04 not got round to trying to get the sound working myself.
Good luck :)
I ran into the same issue with my Asus chromebook. Sound worked fine under chromeos, but only showed "dummy output" under pulseaudio. Managed to fix this about a year ago, after lots of research. I am dual-booting in the traditional sense (Ubuntu is on an SD card), so not sure if my fix works in crouton or chroot situations too. Regardless, here's what I did to fix it:
pgrep alsa. This is supposed to disable alsamixer to prevent issues with the next step. sudo alsa force-reload. It goes without saying, but be sure to save a copy of the recipient system's alsa folders before replacing them.
If this doesn't work, you may need to generate an asound.state file before step 4 (I can't confirm this now, since I reformatted the GalliumOS usb). Instructions on doing this are in the "alsa info" link below.
If you want a really easy solution, just install GalliumOS. It's Xubuntu redesigned specifically for chromebooks.
Tested computer was Asus C202SA (Braswell chipset). System was Xubuntu 18.04.4 installed on an SD card. Dual-boot accomplished by entering developer mode and using the Mr. Chromebox script to flash legacy bios.
Reference material:
Alsa info: No Audio on Acer Chromebook 14 under Ubuntu 17.10
GalliumOS site: https://galliumos.org/
For those interested:
Info on developer mode and script: https://www.howtogeek.com/279308/how-to-restore-your-chromebooks-original-bios-and-software/
Script site: https://mrchromebox.tech/
