Keyboard shortcut for "open a terminal here"
I followed the steps mentioned in in the top voted answer in the above link for my Ubuntu 16.04 and my custom keyboard shortcut for "open in terminal", when a directory in nautilus was opened, worked perfectly.
However I recently upgraded to 17.10, and though the ~/.config/nautilus/accels file remained unchanged, nothing happens when I press the keyboard keys for it now when Nautilus is opened.
I also turned can-change-accels "on" from the dconf-editor which somehow had turned false after upgrading to 17.10
Please help me fix this problem
Kewal Shah
  • 1,044
The issue is with the Compiz, Install the compizconfig-settings-manager
sudo apt install compizconfig-settings-manager
Open CompizConfig Setting Manager and disable the Command plugin as below
Unselect the Commands plugin and it should work.
Hope this helps!
koiralo
  • 99
